We just picked up our first boat and to add to this we are noobs so please go lightly. We purchased a 92 Bayliner classic 2252 in pretty good shape with a trailer. I was able to take the boat out on the lake with the previous owner and the engine didn't appear to leak any fluids, no weird engine noises and started rite up every time. Checked the oil levels before and after a 45 minute spin and it looked good, nice color and no sign of moisture. The exterior of the boat has no damage and overall pretty good shape but could use a good polish which is something else I need help with with. After doing some research I found that 3m polish and a good buffer pad/wheel will do the trick.
On the deck there are a couple soft spots one located near the rear of the boat in front of the rear seat, then spot is about 12"x12" and the other is located in the cabin when you step down between the bathroom and the sink. The spot is about 14"x14" in size. In the cabin seating area under the large pillow seat the wook is rotted out on the left side. After looking around I believe the water was coming into the cabin via a poorly cauked horn and spot light. I would like to repair these few items now that I have sealed all the noticeable spots I listed above.
Can you guys help me with the best way to repair these spots and the correct material? Can I just cut out the rotted board and use a new piece of plywood tucked from below the deck and drilled from the top then glass the top of the plywood?
