Hi! I just happened across your forum, and have had a great time reading the posts. I just got a 7.5 hp Fishing Scott. The ID plate is damaged, so I can make out only the last part of the modle number
(300711 1547). Another part of the tag says that max rpm is 4500, and full throttle is 4200 - 4800. the unit seems to be in good condition. I understand that McCulloch made it. What I need to know is, what lube is used in the lower end? there seem to be several zirk type grease fittings on the unit, what type grease is used? And of course, what is the fuel mix? I am looking forward to getting this toy running as it should push our 12' Livingston nicely. Thanks for your help
