Re: help with a 7.5 sears ted williams
I just went through a McCulloch 7.5, probably the same motor. It's not too terrible to work on, other than the usual screws that can't be reached (slot head screws no less). Definitely print out the service manual and get an overhaul kit for the carb/fuel pump and at least one impeller because you won't want to pull it apart again any time soon. The carb on mine looked okay but the fuel pump diaphragm was stiff and wouldn't work at all.
Also make sure you know how to remove the flywheel without damaging it; a harmonic balancer puller is cheap at any auto parts store. My motor had a damaged flywheel when I bought it, someone tried to pry it off or use a gear puller - fortunately I was able to find a replacement.
There should be a tag on the bottom of the carburetor, make sure you get the correct kit. You should be able to see the tag before pulling the motor - mine is a SUM-20.
If you have a "weedless" drive you need to pull the powerhead to get to the water pump, and you always need to pull it to get to the carburetor. Notice the carb tucked down in there on the left side where you can't reach it?
Once you disconnect the shifter, throttle linkage, stop button, and choke you can fight with the screws that hold the powerhead on and the gasket underneath that's probably stuck.
Then you can see the water pump, but you need to pull the gear case off the lower unit to replace it. The bail-o-matic pump is on top, visible here. The main water pump is under that plate.
