HELP WITH A PICTURE???Mercury 135 Opti.2000
jerryjerry05
DSCN0460.jpg.
Was helping my neighbor and found a tube with a piece of broken hose hanging loose under the hood.
Gotta figure out where it goes???
Didn't take anything apart yet.Just hoping for an easy fix.
Started it up and no oil or gas came out. No vacume/vacum or water?
Neighbor said it tastd like salt comming from the tube????
Thanks!!!
M
Maxz695
Guest
Re: HELP WITH A PICTURE???Mercury 135 Opti.2000
Right click and Edit the picture in paint then go to resize and if it says 100 bring it down to 20 30 or 40 and try it again It must be under a certain amount of pixels to post it. Make a copy of the picture to edit as you will lose the original once edited and if it doesn,t work you can make another copy to edit.
jerryjerry05
Thanks Max, this is the first time it wouldn't take a pic.
After 4 tries it shrank enough and loaded.
M
Maxz695
Guest
i,m not too firmilar with 4 stroke so hopefully the cavalry will be here soon to assist you. There a great bunch on here.
jerryjerry05
Opti is a really over-engineered 2 stroke??
Good power and economy but LOTS of stuff to go bad???
M
Maxz695
Guest
I,m a classic kind of guy affordable dependable and troubleshootable lol Best wishes and hope all goes well.
jerryjerry05
I work mainly on Forces(own 2) and try to work on the easy stuff!!
Faztbullet
It the speedometer pickup....
jerryjerry05
Will look into the speedo tube. Thanks.
