Help with a year
Fishrman
I have an Johnson 30hp and the only numbers i can find on it, is the quarter size disk mounted on the block. The number is R8611755, i cant find any reference on any website to these numbers. Any and all help would be much appreciated.
Thanks in advance,
Fishrman
samo_ott
Re: Help with a year
Did you look around the port side transom mount? Should be a data plate there. Get the model # off it.
F_R
There is no plates of any kind on the transom mount.
That Rxxxxx serial number is a Replacement powerhed, so is worthless as an ID. If the regular number plate is missing, you have nothing to go by other than decals, etc.
