Help with buying a transom saver.
tashasdaddy
Re: Help with buying a transom saver.
you want the foot of the motor atleast 12" of the ground, most savers are adjustable.
Bob_VT
With the motor in the up lock position as in your photo..... measure the distance to the frame. Most transom savers are adjustable and iboats has a good selection here http://www.iboats.com/Boat_Transom_Savers/dm/*******.233532555--**********.412337393--view_id.238448
or here
http://www.iboats.com/Boat_Motor_Supports/dm/*******.233532555--**********.412337393--view_id.238447
On my last bass boat I carried the motor not quite as high as full lock but with enough clearance to clear obstacles...... the bottom of the motor was above the height of the keel.
