Help with engine Mounting
Mudboy68
Hi I've been havnig a problem with spray coming off my motor over the back of the transome at midto high speed. Another boater mentioned the motor may be to low on the transome.
From what I've read and pics I've seen I belive this may be the issue but being a novice at boating I thought I would get a second Opinion from you guys.
Here are links to some pics I took of my engine and transome.
http://ca.pg.photos.yahoo.com/ph/br...m?.dir=/4ee9re2&.src=ph&.tok=phJJwzGB3miNHPwE
Comments and input appreciated.
TIA
Mud
F_R
Re: Help with engine Mounting
Try raising it up to the next set of holes.
Gary H NC
You may be able to go 2 holes from looking at the pics. The cav plate can be about an inch above the hull centerline.Expect some better performance too;)
