stingraymax
- Joined
- Sep 11, 2004
- 93
Hi, I have a 99 johnson 90Hp engine and there is a loud ticking noise comming from my powerhead. <br />It sounds like two metal parts hitting and it goes together with the rpm. <br />From what I can hear it sounds like it is comming from under the fly wheel. <br /><br />The engine starts up very nice and runs stable around 800 - 1000 rpm, it shifts nice and solid. <br /><br />This is already what my mechanic checked. <br /><br />VRO pump <br />Loose magnets under flywheel <br />electric arching <br />piston hitting spark plug. <br />removed spark plugs wire one by one while running to see if theer was a change in noise. <br />top crank bearing <br />the tail oil is clear and no metal shavings in it. Waterpump just completely replaced. <br /><br />And still can't find the problem, next thing he suggests is taking the engine apart ... <br /><br />Is there anybody that can think of something else we looked over or might have an idea what it could be....<br /><br />Thanks <br />Stef
