HELP with finding the correct manual for mercruiser
Bass2mouth
can any one post a manual that i can view for my engine? the tag states.
serial number
L033402
mercury marine
div of brunswick corp
fond du lac, wis
thank you in advance. i cannot find the correct view-able manual.
Bass2mouth
Re: HELP with finding the correct manual for mercruiser
thank you mark. ill take a look.
LtJoker66
My HIN is USP876MKF989 Could I get some help on mine too please?? Thanks you!
dubs283
you need to start your own thread asking questions pertaining your engine/drive issues
the hull id number does us no good here, this is an engine and drive forum - start a new thread with your mercruiser engine/drive serial number
see here: http://forums.iboats.com/mercruiser-i-o-inboard-engines-outdrives/how-ask-question-220416.html
Bass2mouth
looked through the entire manual....... does not appear to be my engine..... just way to many differences.... im starting to think the only similarities are the actual engine tag...... not a good thing..
dubs283
looking at the pictures you posted someone cobbled together your engine with parts and pieces throughout mercruisers history
log style manifolds havent been used scince the mid-80's, and an engine with log style manifolds NEVER used an electric fuel pump, see where this is going?
where is the engine tag you are getting the s/n from??
Bass2mouth
the tag was on the starboard side of the engine on the block by the starter/bellhousing
Ayuh,.... Like Dubs says, it's quite apparent that nothin' 'bout yer motor is original, as much of it just ain't right....
I'm guessin' yer dealin' with Merc SBC parts from whatever the year of the hull, to '98, 'n pretty much Anything in-between....
If ya did up the manual for the earlier vintage of yer motor, 'tween the 2, ya oughta be able to get a handle on what you've got....
