Hi All,
Just found a Johnson QD19 1958 that hasent been seen for years. Its my first go at restoring any kind of motor. (this site is awesome).
What I did so far:
Changed the spark plugs, changed the coils (spark is strong and blue). that took care of the no spark issue with one plug. I also changed the gear oil in the lower case.
Current issues I have:
1) when I try to start the motor, I put it into the start position on the lever, and give it a pull, the handle goes to the shift position by itself, is this normal?
2) when I pull the lever to start it, it sounds and feels like something is slipping, so the plastic piece under the mechanism is not fully engaging to turn the flywheel. What do I have to replace?
3)when I pull the cord, it requies quite a bit of force, is this normal?
3) when I pull the lever, it will start for 1-5 seconds then die. if I try again just after that, it will not sound like it wants to start at all until I let it sit for a few minutes.
After reading through the site, I think what I should be doing NEXT is:
1) change the impeller
2) change the pressurized fuel tank to a fuel pump
3) get a carb rebuild kit.
Do these next items on my list sound like they will be the cause of the above problems? If you could give me an idea on the puller issues as well that would be appreciated.
Thanks,
Ivan
What I did so far:
Thanks,
Ivan
