help with fuel/water seperator
bpd119
I know this is not an evinrude question but i have a sierra fuel water seperator system hooked up to my 90horse evinrude v4. i recently replaced the filter which looks like an oil filter. my question is do i need to prime the fuel system in any way, bleed the air out or anything, i dont want to cause any problems with the motor thanks.
Solittle
Re: help with fuel/water seperator
You do have to fill the filter and lines with fuel. Squeezing the primer bulb until it is hard will do that. It takes less time if you fill the filter with fuel before screwing it down.
bpd119
thank you i didnt fill the filter, i will take it off and fill it up
Gary H NC
Remember to fill it with mixed fuel not just straight gas.I use about half Seafoam and gas.
bpd119
why is that? because there could be water in it? or is it something else.
ezeke
If you have a full sized water separating filter, that much SeaFoam would decarb the engine a little, but might make the run pretty trying to say the least.
Use premix unless you are using the VRO or OMS, in which case use straight gasoline.
