Help with Gamefisher
Lootas1
Just got a 9.9 horse Gamefisher. It runs fine but won't shift. I took apart lower end and found a bunch of needle bearings loose in gear case. Also one tooth gone from the gear that comes out with the prop shaft. It is a Model 217-586231 (and perhaps one more unreadable number) and Serial # 9A-335879. I need a lot of help. First, what have I got? Are parts available? Or should I remove power head and sell it?
ed/il
Re: Help with Gamefisher
Put your model # in google search engin and you will find some info. Perhaps you might find the parts you need.
