help with identifying this adjustment screw - stalls on idle - 1988 mercury 35 HP
rstier
Hi,
My 88 35 HP Mercury is stalling on idle and when you put it into gear. Once you get going, it runs fine. I am thinking it may be a timing /idle issue. My Seloc manual is on the way. I was hoping someone could help me identify what the adjustment is for in the picture below. Thanks!
rstier
Re: help with identifying this adjustment screw - stalls on idle - 1988 mercury 35 HP
anyone?
merc850
That looks like the idle stop screw that advances or retards the idle but unless you've altered the timing I wouldn't move it. Instead, adjust the low speed screw in the carb at 800-1000 while engine is running in gear.
rstier
Ok, thanks. The low speed adjustment may be difficult because it stalls the minute you put it into gear.
sunburnt
turn out 1/4 turn to rich- counterclock before starting. should be some where around 1 1/2 turns from lightly seated.if a new motor to u ,a good tune will help eliminate future probs .fuel pump- impeller- gas lines- bulb -filter water sep type- carb rebuild- plugs- all pretty easy on this motor. good motor ! should last 1000 s hrs if taken care of. check out time /idle specs on sticky at faq
rstier
Ok, I'll give that a shot. This motor is new to me. I replaced the inline fuel filter, fuel water separator, plugs and impeller before lauching and the fuel line/bulb is new. I haven't messed with the carburetor or fuel pump yet. I did mess with this screw in the picture above a little (maybe a turn or so). I am hoping that doesn't throw things off too much, that is why I was trying to identify it. Lesson learned not to turn screws that you don't know what they do! :)
So that being said, do I now have to look at the timing procedure or does that screw in the picture above not impact it?
Thanks for the assistance on this one!
