1979 85hp Spirit (Suzuki)<br /><br />OK, I'm trying to replace the impeller on my motor. So, I read the manual for how to disassemble the water pump. Step one, remove the gearcase. Makes sense, now how do I remove this.<br /><br />One of the first steps is to remove a cover from the front of the drive shaft to disconnect the shift rod. Sounds good, but I can't seem to find the cover that they're talking about. They don't give a picture of that with the whole engine, and since this is a Spirit, not a Suzuki, I'm not 100% positive it's going to be where they describe it.<br /><br />To make life easier I took a couple of pictures. Here's the motor:
<br /><br />I'm not sure if they mean that big bracket looking thing right above the gearcase. I tried taking the nut off that you can see, but the bolt going through there seemed to be supporting the weight of the engine, so I don't know that that is what the manual is referencing. Or maybe it's higher up, but I can't see any way to get anything else off.
<br /><br />Here's the page of the manual I'm referencing. <br />
<br />See, there is one picture in the upper left that's a closeup of that cover being off, but I can't tell where that would be. I'm on step 6 of that procedure, by the way, if you want to see the description.<br /><br />So, anyone have any ideas?<br /><br />Here's bigger version of the other pictures, for those with higher speed connections who want a closer view:<br />The motor: Big picture of motor <br />The manual page: Big picture of manual
