Quadzilla724
- Joined
- Aug 5, 2012
- 9
I'm new to boating and bought a boat and nice trailer. The problem is the lights are all jacked up. Here are the symptoms. I'm hoping you can tell me where I need to start looking, because I have NOOOO idea....
Left Turn Signal = Left Turn Signal
Rt Turn Signal = Right Turn Signal
Running Lights = Running Lights
Brakes = Nothing
Left Turn Signal w/ Brake = Railroad Lights (rt & lt signals alternate)
Right Turn Signal w/ Brake = Railroad Lights (rt & lt signals alternate)
Running Lights w/ Brake = Nothiing
Hazards = Nothing
I'm 99% sure the tow vehicle is fine because I had just pulled my friends trailer the week before with no issue. I checked all the fuses just in case and all were good.
I checked the ground wire on the trailer, cleaned it, reattached it.
I found a flatted part of the wiring near the right light and, cut it out and spliced it.
i cleaned any corrosion I could find on the harnesses.
Nothing changed. Nothing worked
What should I do first?
Tow vehicle is a '03 trailblazer with factory adapter (7-way to 4-way?). Trailer fits into that.
Should I rewire the trailer 4-way first? Not sure of next step or best way to diagnose. I don't have a lot of electronic testing equipment, so if you suggest I use something like that, please let me know the name of it, cost and where I can get one.
Thanks, from a rookie!!!
Brakes = Nothing
Hazards = Nothing
