a70eliminator
- Joined
- Sep 9, 2007
- 3,762
Hi, we have a 1990 5.8 ford unknown hrs.
I did a comp test on all 8 cylinders today (engine was cold) if that matters?
I opened carb and with all 8 plugs removed battery a little on the weak side if that matters?
1=110 5=100
2=120 6=80
3=110 7=110
4=110 8=120
I've never had any problem with water in cyl. and plugs looked pretty good.
These comp numbers all seem low can this be from cold engine? I've drained the block for winter and pulled hoses so starting it was out of the question. I figured cold or not the reading would still be viable being I was mainly looking for consistancy. Do you think the 80psi in #6 constitutes a tear down this winter?
1=110 5=100
2=120 6=80
3=110 7=110
4=110 8=120
