Evinrude 35 M# E35ELCND SER# E0098512<br />Can anyone tell me what manual to buy, what year motor this is? I think the lower unit is bad the propeller doesn't turn.
Hi Echopoint,You have a 1982 35 hp electric start Evinrude. remove the prop and see if the prop shaft turns. Drain the lower unit and see what comes out. oil? milky? water? rusty?
1982 35 Hp motor, i may have a rebuilt lowerunit if in need let me know, if i can be of help, i will also have all the parts you would need, Frankie<br />918-786-8180<br />fmrs@greencis.net
Thanks for the help on my 35 evinrude.<br />Found a manual, clymer evinrude/johnson shop manual. Thanks<br />Now the problem; I found the clutch dog is broken,shift lever,and the cradle.<br />Does anyone have these parts that I can buy. Maybe a seal kit also. Everything else looks to be ok. The oil when I drained it was clean and clear except for some chips from the cradle.
