Hey everyone, I am leaking water into my boat (1994 Bayliner with Chevy 350 and Mercury AlphaOne stern drive). I took it out to the lake yesterday and pulled it off the trailer, started the motor up and drove over to the dock. Shut off the motor and opened up the engine hatch. What greetd me was the pleasant sound of water trickling into my boat at a large rate of speed. After a few minutes I turned on the bilge, and it was able to keep up with the amount of water inflow, but just barely. I can pretty clearly see where the leak is coming fom, but I don't know why it is leaking here. Here are 2 pics of the site where it is leaking in.<br /><br />
<br /><br />
<br /><br />I went to West Marine and bought a Clymer repair manual. I have searched through the book, and I read the entire chapter on cooling systems. My boat appears to be leaking water from around the driveshaft--where the driveshaft enters what I think is the "engine coupler". I assume there must be some type of seal at this point, and that the seal is shot. In the first pic (from a top view), the driveshaft is marked with an arrow, and the "coupler" is marked with a red x. In the second pic (from a side view), again the driveshaft is marked with an arrow, the coupler with an x, and the water intake hose (which continues on around front to the water circulating pump) is marked with a blue circle. You can clearly see that the water hose is above the driveshaft. The water is definitely not leaking from this hose at any point. It is leaking around the coupler/driveshaft interface, and is being directed from the engine side of this interface. I don't think this driveshaft is "cooled" by lake water, and I have no idea why water would be leaking from the engine side of this coupler. Any ideas?
