Help with old mercury.
Jshadwick
Hello, I recently boat my first jon boat, it is a 1970 duracraft 1436. My father in law gave me a 1975 Merc200 20hp. When he gave it to me he told me it was having a problem pushing his old boat and that he had it in the shop getting gears replaced in the foot. I was thinking it may have been a cavitation issue, but now I think it may be the prop. I took it to the lake and it would do fine just over idle, but when I tried to accelerate I didn't gain any speed and the motor would go up in rpms.
I brought the boat home and did some research, so I marked the hub with paint and ran it in a barrel full of water. I was at about half throttle for about 15 seconds and went to almost full throttle a couple of times, but when I took the prop off the lines were still lined up. judging how bad it did at the lake I thought that I ran it long enough for the hub to slip. Is there a difference in running in open water and running the motor in a barrel? Or, could I have another problem. Any comments or help would be much appreciated, Jeremy.
mercurymang
Re: Help with old mercury.
Runnin' in a barrel at half throttle should have moved quite a bit of water in there. Did that happen?
Jshadwick
The water was moving around in the barrel a good bit. It was definitely churning it up like it should. But from looking at the lines I drew on the prop and hub nothing slipped. I thought this would have been enough because it did so bad at the lake. Im wondering if the extra force of pushing the boat through the water made it slip in the lake and not in the barrel.
mercurymang
Sounds like you need to do the same experiment but out on the water under WOT. Just to rule it out.
