Hi all, I'm new at this but here it goes. I have a 95 Starcraft Starcaster 1700 alum. bass boat with a 1995 40hp mercury. I hit a metal beam under the water and shaved off a little of one of the 3 blades. It has stamped on it 48-73138 A40L 14p. I figure that the 14P is the pitch but nowhere on it is stamped the diameter. Best I can figure it's 10 1/4. My main question is do I have to stay with a 10 1/4 if that's what this one is or can I go up to a 10 3/8. 2nd, what would the L in A40L stand for as when I try to match this prop with am OEM most end with just A40. The WOT on this motor is recommended 5,000 - 5,500 rpm. Actual is approx. 4,800. Again, I'm new to boats and boat motors so I hope you can excuse my inexperiance.
