Capn Klaus
- Joined
- Sep 23, 2009
- 23
Hello all,
I was at the local fiberglass shop here in Calgary and was talking to the experts there on fiberglassing my stringers and transom. Here is what they said to do. Since my boat is a 1976 era boat, it was put together with resin. Epoxy and resin apparently don't like each other...can cause delamination. They suggested I use resin for all fiberglassing BUT use epoxy for all gluing...transom plys, transom to outer skin, bedding material. AFTER I have fiberglassed the stringers and transom, I am to put a coat of Gelcoat overtop of this to give an extra seal to moisture penetrating the resin as they state resin is only water "resistant" not water proof.
I should also point out that I will be spray foaming below the deck so there will be no open spaces.
Any thoughts on the above procedure would be greatly appreciated as I am ready to purchase my materials.
Thanks in advance,
Klaus
Thanks in advance,
Klaus
