Help with seals, bearings, and seal.....
frustratedboater
Wonder if someone can help me find some bearings and seals for my engine? I have already ordered and received gaskets and stuff from this site (iboats...) and had success and good luck so far, but later discovered that I will need a few other items and can't seem to find exactly what I need. Can someone please help find the right parts here online?? They will be for an 87' Mercruiser 470, 224 CDI.
1- Large thin seal (opposite the PTO end) for the crankshaft-Mercruiser #26-90925, 2 small seals for the cam shaft that sticks out of the front side of the engine (back of the water circulator pump)-#26-97530, and I guess standard size bearings(with the cap on the rod, the inside demensions measured 2.652, and the crank journal at 2.494?), for the connecting rods which need replacement.
I would appreciate any guidance with this. The parts catalog portion doesn't give much description on some of the seals. Thank you,
"Frustrated-boater"!
