Help with Sears ESKA impeller please
mikekr
Hello
I'm currently rebuilding a 1974 sears eska motor. (model #217 5949-1) Can someone instruct me how to remove the impeller from the shaft? There is a small hole on one side of the shaft just above the impeller????
Thanks in advance
truckintyler
Re: Help with Sears ESKA impeller please
the impeller just slides up the shaft, on my 7.5 anyways. there a pin behind the impeller that stops it from spinning on the shaft.
i just pry it up. but do as you will
mikekr
Thanks
I ended up using my dremel to grind it off. Just corroded on. What plug are you using? The book says J13-Y but its discontinued.
