Re: Help with serial number??
If you go to mercurypartsexpress.com, using your serial number you can see exploded views of your motor. See the sub-section on gear housing (drive shaft).<br /><br />The water pump repair kit is p/n 46- 96148A 8<br />or, the impeller only is p/n 47- 89984T 3<br /><br />iboats.com sells that repair kit as follows:<br /><br />$34.71 - PUMP KIT WATER S/S>46-96148Q 8 <br />Compare at $40.83 <br />Part # 46-96148A 8<br /><br />You can find it at iboats by searching for "46-96148A 8" in the marine store.<br /><br />Same with the impeller only:<br /><br />$20.56 - 710-47-89984T 3 P >IMPELLER <br />Compare at $27.10 <br />Part # 47-89984T 3
