Help with Stalling
mrtommy03
Hello,
I have a 1994 Four Winns Horizon 180 with an OMC 5.0 Cobra.
Recent Work Done:
  • Rebuilt Carb - 2 weeks ago
  • New Starter - 1 month ago
  • New Fuel Filter - 1 month ago
I've cleaned the Flame Arrestor...It's sparkling clean. When I start it in my driveway, it sounds and runs perfect!
The Problem:
No problems starting it up, backing it away from the ramp. I can go 5 mph like a champ, but the second I gradually take it up past just 1200 RPMs, it dies on me. Today I was unable to get over 5-10 mph. At one point it went up to a whole 1500 RPMs...Woohoo.
Anyway, anyone have any ideas??
Thanks
can-amsledder
Re: Help with Stalling
When did this problem start, before of after the carb was rebuilt?
mrtommy03
Well, it was rebuilt about 2 months ago...Then I had it rebuilt AGAIN about a week ago. After this second time is when it started stalling every time I tried to give it some gas.
mrtommy03
Come on People! I know someone out there has got some good tips or ideas on what to do here.
HELP PLEASE!
Ayuh,.... So it was Rebuilt,.. Twice...
The Question is,... Is it Working properly,...????
You're There,.... We can't see a damn Thing....
It takes Fuel, Fire,+ Compression, All at the right Time....
You tell Us which of the 4 is Missing when it won't Run.....
arrkerr
Maybe not getting enough gas for whatever reason? Plugged fuel line or fuel filter or water seperator? I know you have a new filter, but maybe try removing the fuel line from the cab and sucking gas with a pump and see if it can pull enough gas with little effort.
If not that, has to be the carb or bad/weak spark. I had somewhat similar problems with my boat dropping dead after X minutes and my coil, which tested fine, was crapping out after a few minutes.
Is the timing OK and ignition components all gapped correctly, etc? Don't know if thats breakerless igntion or what...?
jtybt
Sounds more like fuel delivery problem. There are tons of causes. First check your filters and anti-siphon valve...I'll let the others fill in the rest.
