Re: help with swim ladder replacement
I just replaced my 3 step with a 4 step and it was a real PITA
The bolts go through the swim platform and there should be two 1/4" aluminum backing plates.
The nuts should be "Lock nuts", so if yours are coming loose, then the nylon locking part
is probably worn.
Now the fun part.
The ladder I replaced did not have the same bolt holes as the original, so I was only able
to use two. I filled the two unused holes with 3M 5200.
To get to the nuts, I made a wrench extension out of some aluminum conduit and jammed
the 5/16 open end wrench inside. Once the boxed in was secure on the nut..I had a buddy
unscrew the bolts. The nuts fell into the bilge, but you can get them out easily.
Once you get the holes drilled...in the swim platform, you'll want to pre-drill the backing plates..
I super glued the lock nuts on the backing plate and was able to reach far enough under
the swim platform from inside the boat enough for my buddy to catch the 1st few screw threads.
Before you tighten everything down...put a nice glob of 3M 4200 between the swim platform
and the ladder and onto the bolt threads.
Once both bolts are pre threaded, use the conduit and wrench extension to hold the lock nuts
while the buddy screws in the bolts.
ENJOY!
