I have inherited a Pontoon boat with a 1994 Mercury 40 HP 4 Cyl 2 Stroke. Serial 0G038000.
If I exceed 4200 RPM's I get a steady overheat alarm. Stays on until I slow down and then it shuts off after about 10 seconds or so. I have changed the water impeller twice. I'm now looking at the temperature sensor and will take the boat out soon to determine if it actually is overheating. Going to do the splash test and use an ir temp reader.
While messing with the temp sender cable (tan with blue wire by spark plug 1), it came apart. See pictures below. Second picture shows where it screws into.
I'm trying to identify this part and find a replacement. If I go to Mercurys site and type in my serial number, it says 40 HP 30 JET as the catalog name and if you go into it, it shows 1040412PD as the model number. If you look at the Cylinder block and crankcase assembly, you can see the temp sendor as number 30. The problem is that drawing doesn' t really look what I have. See picture. I thought about just re-soldering this but it may be better just to buy a new one. If I can find it. I'm wondering if the model number I listed is correct. Any ideas on where to find this or determien the proper part number.
Thanks
Thanks
