maineiac5586
- Joined
- Feb 14, 2009
- 771
I have a 1994 Johnson 30 hp tiller electric start. I am trying to adjust the max timing stopper because when I got the outboard the stopper was adjusted 1/2 to 3/4 inch away from the edge of the timing plate. I am using the Jim Reeves timing method (I have both spark plugs out (spark plug jumper set to 7/16" on #1 cylinder), I have the throttle open fully and timing light hooked up to coil #1. During the crank test before any adjustment the timing was way advanced. The problem I have is that in order to achieve 26 degrees timing (4 degrees less than stated 30 degree indicated on starter motor as per reeve's test procedure) I have to adjust the stopper screw so far in that only a little nub sticks out (not enough to get the lock nut back on). I also noticed at 26 degrees the throttle plate is hardly opened and the roller is not making contact with the timing plate. Any idea what I am missing here or doing wrong? I don't see any way to move the timing plate closer to the stopper location in order to have enough adjustment thread of the stopper bolt sticking out (without severely advancing the timing). Help here would be appreciated (I tried following the procedure in the repair manual but to no avail)
The pics show how everything is when the timing plate is against the stopper (26 degrees set) (with stopper screw screwed way in), also look at the roller distance from the plate and throttle plate position
