help with trim motor
C Perini
my trim motor on my '86 90hp merc is only working going down, nothing when switch up. The motor is now down and when I turned the override screw to override the hydraulic, the screw sheered off. what the heck can i do now to get it up ??
DHPMARINE
Re: help with trim motor
Jim,my guess is a bad trim solenoid.Your motor has three of them.All have red and black wires .Two also have the trim wires you need to jump.One has a green wire for down,the other has a blue wire for up.The solenoid with the blue wire...use a jumper wire and touch the heavy red wire to the small blue wire.If it goes up okay... replace that solenoid.<br />DHP
C Perini
DHP, You were right, I jumped the trim up solenoid and up she went. Great call!! Is that solenoid hard to find? Thanks again.
DHPMARINE
Thanks for the reply.I am trying to promote positive replies .Don't know where in MA you are,but almost any marine dealer should help.<br />DHP
