help with water leakage from pump
bpd119
I recently installed a water pump on a 1986 evinrude 90hp v4. i just ran the boat in the lake, and it has strong water pressure coming from the tell tale. although i noticed water leaking out of the midsection. its coming down from the midsection onto the lower unit. it seems to be from the water pump because its flowing quickly. it only seems to happen during idle not when the boat is at WOT.
bpd119
Re: help with water leakage from pump
which one would it be. i just changed the one in the lower unit
bpd119
Can I run the motor like this? I really dont want to pull the lower again, it doesnt leak bad, and it has plenty of water pressure
tashasdaddy
have you checked it running with the cowl off? to make sure it is not coming from the block.
bpd119
I have checked it with the hood off, and it doesnt seem to be coming from the block.
jtexas
... it only seems to happen during idle not when the boat is at WOT.
hope you don't mind I just had to ask - did you really hang off the boat at WOT to check this out? or another boater?
while I'm at it one nuther question - I see the word "BOAT" printed on your stern - is that the name of the boat, or is it just for identification purposes? Does your truck say "TRUCK" on the tailgate? :D
iwombat
JTextas, my guess is it's kinda like the batcave where everything has a nice neat label.
Maybe it's really B.O.A.T.
bpd119
haha the boat part is an inside joke with my father, and yes i had a friend look at WOT.
but seriously, i need help with this i dont want to put it in for the summer and worry.
Dhadley
There should be a round rubber seal piece on the shift shaft. Are you sure it was there when the lu went back on?
bpd119
Ok I just pulled the LU again. the o ring on the top of the drive shaft is missing, i know it was on their when i put it in and also i forgot to put on the little round seal on the shift rod, im a dumb *** could this have been the problem?
Dhadley
If that was the problem you'll know in about 10 minutes..........
Dhadley
And don't think you're the first, or only one, to have left that piece off......
