Help with West Bend/Chrysler
pilotmanmk11
I have a West Bend/Chrysler 20 hp and i can not get the flywheel off. I can't use a flywheel puller because the threaded holes on top of the flywheel are reamed out. I am unable to a large puller to get it off, how else are you able to remove the flywheel?
roscoe
Re: Help with West Bend/Chrysler
Note, this may cause damage to the flywheel or what is under the flywheel.
Loosen the nut 1 or 2 turns, do not remove the nut.
Pound on the flywheel with a mallet, and pry up on the flywheel with a pry bar.
Be careful not to damage the other components.
Hopefully it will "pop" loose.
