Help with wiring new Alternator on AQ130D
big_b
My Alternator is no longer working (probably voltage regulator)
I noticed there is a short in the starter solenoid probably causing the problem. So I am replacing the starter solenoid and the alternator with a higher amp alternator.
The current alternator is...
PARIS RHONE
14V - 35A
A13 N 35 M
G3
L
REGULATOR
14V
YL135 96 1883
All the replacements are 12V .. I would not think that this would matter much and would still provide enough charge for my batteries.
In the picture can someone tell me where the wires should be ran from each terminal ? I want to make sure all the current wires are correct ..
Thanks
Branden
big_b
Re: Help with wiring new Alternator on AQ130D
Can anyone tell me the proper way to wire this ?
Thanks
