help with wiring new delco distributor to oem cobra loom and esa
matthew daley
hi just binned my old 4.3 and now fitting a 5.7 crate motor i have a few problems with wirring
1 new distributor is a delco est and coil missing 1 plug out of dizzy
2 how do i make esa work ive read you can wire micro switch to the plug ime missing like a mercruiser set up and remoove the omc esa iff so how
3 how to wire fuel pump using oil switch whitch is 3 pin i dont have a light just a guage but i want to wire a low oil alarm buzzer
hope you can help me allso i have lots of 4.3 bits on ebay and a set of risers that are 8 month old on ebay
Re: help with wiring new delco distributor to oem cobra loom and esa
Sorry don't understand what your saying, please explain what one missing plug fro distributor means?
Since you have the delco est I would suggest using the Merc shift interuptor. This will require you to pick up some pats to install. If you use the EST type you will also need some items. What was the original serial number for the 4.3 engine?
If you use an electric fuel pump you need to wire it so the fuel pump turns off if the engine dies, or you loose oil pressure. This is a safety issue. 4_3L elect diag.jpg
