Help with Yamaha FT9.9EXH float adjustment
oldiron52
Could anyone help me with what the float adjustment should be on a 1987 Yamaha 4 stroke 9.9 HP Model: FT9.9EXH, Code: 6G8, S/N: 782010 outboard motor carburetor? The carburetor is stamped 6G800 TEIKEI Japan. Any info on this carburetor that I?m finishing a rebuild on would be very much appreciated!
Thanks...Scott
sdsaw
Re: Help with Yamaha FT9.9EXH float adjustment
Scott,
I don't know if this is too late or not, but for a 1988 model they show a float height of 25.5 +.5mm (1" +0.020)
This is measuring (with the carb upside down) from the surface that the float chamber seals on (not counting the gasket) to the highest part of the float.
Hope this helps,
Scott
oldiron52
Sdsaw - You were in plenty of time and thank you for the valuable info you provided. I had to order a few parts so it took a little time to do the rebuild on the carb. The motor now runs perfect thanks to a little help from you?.Scott
