Help with year of a 5 hp Johnson
Pal 03
I had this motor gave to me and know nothing about it the model# is LD-108 and the serial# is C453449 any help would be apreachied Thanks in advance
Pal 03
Re: Help with year of a 5 hp Johnson
Thanks for the help dose anyone know where I might be able to find parts to fit this motor I am not shoure what part is gone yet but I will update when I get more info
Paul Moir
NAPA autoparts carries most commonly replaced parts on it. Many internet sites carry the same stock. Ebay and sellyouritem.com have some of the more hard to get stuff, as do older Johnny/Evinrude dealers. You might have an outboard junk yard around for non-consumables. Finally, Twin city outboards apparently has everything under the sun, and are often recommended here.<br /><br />I think rolmops interpreted your LD-108 as LD-10S, which works. You'll want the correct model number when ordering parts.<br /><br />Hope this helps!
Pal 03
Thank you I was also woundering about the gas mixture on this motor I have been using 25:1 and it seems to work ok but was just woundering if that was right
