I have been sweating over my tilt and trim unit now for a couple of hours, and can't seem to find the problem. The problem I am having with it is it will tilt up, but won't go down. It has been working flawlessly untill a last week. It is a 3 wire T/T (blue, green, red) with the up wire on the solenoid. I have gone through my manual, and although very detailed, is a little too techinical for me. I have greased and inspected the tilt tube, and don't see any problems with it. I bled the manual release valve on the side of the bracket, and blew hydraulic fluid all over the place. After releasing the fluid, I topped off the resevoir. Still functions up, but not down. The motor/pump? is coming on when I energize the down tilt. I am attempting to post some pics of my t/t unit in hopes of someone recognizing the problem and using the picture to explain to me where/what to do. I have been told to remove a check/releif valve because air might by on the backside of the pump causing it to lock up. I am not sure exactly where this valve is? The diagram in my manual is not pictures, but yet a rough diagram of the hydraulic system routing. Any help would be SOOOOO appreciated. Not sure where to look next.
I don't want to get into tearing into this thing too much if I don't have to. Thanks guys!!!! <br />
<br />
<br /><br />I know the bracket and T/T unit looks bad. I recently painted the bottom of my boat and the motor, but didn't paint the bracket and T/T unit.
