Re: HELP! Yam 250ox66 wont pull over 15 GPH and rpms drop out above 4k, why?
Thanx rodbolt for replying to my problem, well I bought the boat used in 2002 so it was 3 years old so I can't tell u what maintenance was done before I bought it but I can tell that as far as I can remember at least 2 years now the same motor held for a minute or 2 at WOT would go into slow mode or what felt like it was slow mode (rpms drop down to day idle)....if i backed off throttle then powered back up it would be fine.....I never cruised at WOT throttle or higher than 44 rpms so it didnt bother me that it did this...just at end of last season the motor started dropping rpm now at say anythign held over 4k for 5 or ten mins...that is when I had a mechaninc start to work on it..... All maint. I have done since i owned the boat was change plugs each year, change lower fluid, change water pumps. Nothing else...since this problem at end of last year I have changed 3 low pressure fuel pumps & the mechanic thgt it mite be high pressure pump so he changed that but thats not it so he gonna try some other stuff (next he will bring down a 5 gallon tank and hook up directly to rule out hull fuel system) and put my old pump back in...he did put a fuel pressure guage on it and said when rpms fell off it was loosing pressure... What else should I reccomend he try?
