my motor will not start.ive got fuel pooring out the carbs w/ choke engaged,fuel on the plugs,good spark,compression 115-125.tryed premix into carb trick still nothing.have computer in garage for realtime help if available.
You've got all three things to make it run. Check for a sheared flywheel woodruff key. Maybe your spark is at the wrong time. If you take off the flywheel nut you should be able to see the key without pulling the flywheel
awesome response kinda!?heres the deal when i got motor lower unit was FROZE but fella had it turning over stuck in gear,dont get how!thought two weeks ago about possible sheared flywheel key even asked about it here w/ no response.that was before startup attempt.then actually had it running for 10 seconds w/o lower unit.so i dont know what to think here.could it have been a fluke startup?any help is appreciated.youve been very helpful to me walker in th recent weeks ,i thank you.
Does that motor have one coil pack I cannot remeber the year they went to four. If so the last time I ran into kinda that problem where the flywheel key was sheared I found alot of metal shaving in the distributor under the Fly wheel that caused a lot of problems and along time to find.
When fuel pour out your carbs, the float is stuck and mean very dirty carbs, all you need to do is clean them out properly, soak in carb cleaner for 24hrs then blow with compressed air ....
her are some pix of the remaining pieces of my carb kit(s).i know about the metal plugs but what im unsure of is the white plastic caps and roll pins.the carbs are pooring gas out and wonder if the plastic pieces not being in there is the problem.by the wat the new needles were a bit longer than the old and the new also have a grove for the retaining spring. old setup had neither.
Same thing happened to me ran great the next time I tried to start gas came out the carbs and would not start. turned out the flywheel key sheared ( I went through many other things before I found it), 99 cents and right back on the lake
waiting for my neighbor to get home so i can borrow an 1 5/16 socket and puller.go figure he works past 8 theone night i need him!my luck sux w/ this boat.
any body know what those white plastic pieces are for?
shes running great now.turns out the new surface gaped spark plugs i put in were the problem.put in old autolite 2634 and she fired right up and sounds great(loud)!im stoked.ill sleep good tonight.
peace
