help
njgreggk
just found out my tilt motor compleatly rotted through and engine will not lift the manual release screw will not turn. i was able to knock out bottom pin and lift motor manually couple of inches to see motor is destroyed. do i need to pull the engine now to get to it to replace or is ther another way. 200hp johnson ocean runner 1997 thanks gregg
tashasdaddy
Re: help
best to pull it. cherry picker comes to mind. PLEASE, do not use help for a title!!!!
