help???
oldgradywhite
My friend has a 2001 70 evinrude 4 stroke. Water is getting in the oil any ideas where it could be coming from?
Faztbullet
Re: help???
How much water:confused: A stuck t-stat will make engine run to cold and crankcase will condensate "milking" up oil.....
oldgradywhite
Re: help???
I should say if you run it for and hour and it moves up the dip stick noticable.
Faztbullet
Re: help???
Sounds like powerhead mounting gasket failed, the parts are the same as a Suzuki DF70 if dealer dont have them
oldgradywhite
Re: help???
Is that the gasket where the motor hooks up to the leg? is it a big job? I thought it had to be a bad gasket somewhere.
Faztbullet
Re: help???
Yep...
