Help!
Bob eskew
motor runs good in neutral took it for a test run wont or doesnt run wide open like its not taking all the gas anyways its an 6hp evinrude fisherman not sure what year serial # is 6302SJ 02377 any suggetions would be great thanks
robert graham
Re: Help!
Check/clean fuel system from tank, vent, filter, pump, fittings, hoses, then you may need to remove and clean carb, probably dirt/water/trash in carb/jets.
Bob eskew
Re: Help!
ok cool i"ve checked it all hoses/plugs thinking jets hoping thats all anyways anyone no off a site i can check the year with serial numbers
