I have a 96 evinrude 150HP oceanpro that is leaking fuel out of an orifice on the front of the main body of the carburetor/throttle body assembly. The attachment shows an arrow pointing to the orifice. It appears to be a brass orifice with nothing attached to it. Each of the 6 bodies has one in the same location. Only the bottom starboard side is leaking fuel while the engine is running. It pours out of it like there should be a hose attached to it or something. Obviously it shouldn't given that none of the others are doing this. Any thoughts on what is happening here and where I should start? Thanks in advance.
