A LIDO CRAZY
- Joined
- Jul 5, 2004
- 12
I am prepping to finish glassing in the floor and transom, the floor wood was ok just needed to dry so now 2 months later im ready to seal off this weekend and my tarp most have got a small hole and let rain water get on the floor and in the hull and stringer area. I can't afford a major delay. there's not a extreme amount of water but enough to wet the bottom of the center stringer. my real question is should I maybe pour some antifreeze in there and then drain and force dry or just force dry. someone once said that antifreeze will stop rot and Im afraid there's a good chance that this will get sealed up with a signifiant amount of moisture still in the hull because time frame will NOT allow this wetness to completely dry. I should say that this is a very old boat with no flotation foam in there to soak and hold the water so what do you guy's think
