Help!!
Fixxer upper
I got this boat for free and I can’t find any information on it but it’s says it’s a 1986 sea wind i may be be wrong but it’s a company that’s out of business please give me anything on it new to boats also need to know the size of motor I’d like to replace it due to it being in bad shape
  • IMG_2359.mov
Welcome aboard.
Just as an FYI, your free boat will be extremely expensive to get it operational.
the motor is the cheapest part of fixing the boat. the old OMC brands such as the boat you have there were not known for great build quality. expect to pour about $5k into the hull
before you spend any money on the boat, get it registered in your name.
if you do not have a title / bill of sale, you wont get it registered without it.
Fixxer upper
Welcome aboard.
What’s it’s you see wrong with the hull?
jbcurt00
Looks like it's been sitting outside uncovered,
As a 38yr old boat, it's likely to need extensive work below deck and a new transom. Plus a new interior & motor
its a mid 80's OMC brand. so the build quality was garbage. most rotted and fell apart in the 90s
the maximum life expectancy of a boat designed in the 80's is about 15 years without major work.
Fixxer upper
Damn guys so did I get handed another man’s trash!?? Iv been looking for a project I’m will to get work to it but needs help from fella like you
Fixxer upper
Welcome aboard.
Also is already registered to me and clean title
The motor is an ----" OMC Seadrive " -----Nothing but a longshaft outboard with special bracket to tilt it clear of the water.-----If it is a V-4 it is about 115 HP.----A V-6 could be 150 + HP .------Model # of the Seadrive is ?------Nothing like rebuilding a boat that you have now.------It is a lot of work if transom / stringers are rotten.-----And it takes longer than you think.-----Lot of smiles when you are done.------Post the all important compression test values on this motor.
Fixxer upper
Look for another model # somewhere.-------Perhaps inside on the lower cowling.
