Re: Henrod torch for welding
I promised an update to my original post. I did buy a Henrob after doing considerable reading and research. I read the pros..and cons. Now that I have one i can elaborate a little.
1st I have to say that after 40 years of stick and a little torch welding I was completely ignorant of the possibities to gas weld aluminum, stainless, cast iron, and chrome moly. My dad was a blacksmith/machinist in a steel mill and started me out long ago. The finest craftsman I ever knew, I think even he would be surprized. A little reading proves that aluminum has been gas welded for far longer that any other method.. 100 years vs 50 or so for modern methods and electronic machinery. Gas welding in the aircraft industry was dominant through the 80s, yet seems to have become a lost art. Reading gave me fair warning that there is a learning curve. Even the experienced call it "tricky at best." True. If you don't have a lot of patience and determination, then I would advise against this totally amazing tool.
IMHO the Dillon- Henrod-Cobra (DHC) torch is a litle pricy at $350 or so for the torch and cutting attachments. However, the patience and determination factor comes into play if you shop around. I found half a dozen "only used once" and "new in box never used" and bought one for 200. It operates with a variety of tips @ 4 PSI OXY and acetylene. This is very critical. At such low pressure standard regulators are wholly inacurate. Lesson one, it has to be set up right- particularly for aluminum. I spent the first day trying various setup methods for getting the right (neutral) flame while blowing holes in thin aluminum. I suspect that this is the reason they are plentiful in like new condition. Otherwise, add $400 for two stage regulators to dial in the correct operating pressures. Add aluminumn welding flux-not brazing- had to be mail ordered. Add $ 60-150- for special eyewear to see the puddle through the orange flux glow. There is a learning curve to applying the correct ammount of flux and proper cleaning.
Welding/cutting steel-No problem. Stainless, harder but with time good results are very realistic. .040 aluminum sheet...man oh man is it "tricky." Beautiful flat welds with full penetration....no cracks.....except when you pause that extra split second and full penetration becomes a gaping hole. Arrrgh. Any alum over .060 needs preheating. Another lesson. Give me a couple of weeks and Ill post some pics.
Cons- The pistol grip and weight of the torch is way heavy and very hard to get used to. I have had my hoses wrapped around my shoulders (not good) and have experimented with holding it different ways. However, this old dog loves to learn new tricks and after 3 days of practice/learning the tool, I am overwhelmingly impressed. I have no illusions that learning this thing won't take considerable time. A do it yourself boat mans dream tool. I welded some thinwall EMT (electrical conduit) just as pretty as could be. Aluminum tube is way harder, but there are so many projects for my pontoon. I have not tried cast..yet..but the number of times that I wished I could weld cast
