Re: here is my winter project
EEwww. It looks like they have been glassed-in. Is there rot in or around the boxes? If not, (and if it were mine), i wouldn't mess with them. Measure them,and get seats to fit the eexisting boxes,or build around them.<br />You could square-up the area between them, glass the edges of the existing deck, then cut a piece to fit. You could make a hatch there, to stow spare props and tools in the bilge. You will Also have to install and glass-in stringers for the sides, and share the bulkheads (half-n-half) with the existing decking. Those bulkheads look like they got some rot too,or is that just water marks?<br />I just took another look...Big picture..I got a hammer just like that! It looks like that side must be ripped out??<br />eww. You might be able to take a dremmel with a cutting blade,and cut the glass all the way around,then take that hammer and bust it out. The center of the box looks higher than the actual deck in the photo. Is it? If so,it may be screwed into the decking under the glass.<br />Is this a Bayliner? (just curoius, becuase the construction looks like Bayliner at the boxes and the real well).<br />At any rate, when you get done, send my hammer back to me. LOL
