malayan
- Joined
- Sep 2, 2008
- 9
I have a 17' Maxum Open Bow 2550 lbs with me in the boat & Trailer on scale alone. ........ Subtract the average trailer weight.
I have a 85 HP FORCE Outboard
Mounted now is a #072127 Michigan Prop 13 1/2 Dia 15 Pitch keep for spare only (badly worn out).
I am acheiving 4200-4500 RPM @ 30 MPH (Just me in the boat)
Planes pretty easy starting at about 20-25 MPH with the Stingray Hydrofoil Stabilizer... then increases speed to 30MPH @ 4200-4500 RPM.
(should I be using this stabilizer?..Came with boat).
Throttles fine & on plane all seems fine.
Should this be correct to use this boat & prop for tubing and Knee Board?
(Have not bought my tube & Board gear yet either).
or should I change the pitch?
One last question please...
Can I pull Knee board & tube from the mount on the stern of my boat or do I need to install a Board Tower?....if so
I am a fabricator by trade so maybe I can weld my own for cheaper
Just need specs for hight & mounting suggeestions.
Thanks..You guys are great just to sit and (read)learn from
