Brad-nTrish
- Joined
- Mar 12, 2003
- 36
Hello again,<br /><br />Well I got the 1980 85 horse johnson outboard home an put on the boat. Started/ with earmuffs runs like a top. Now my problem... My tilt and trim worked great, new motor was just installed when I bought it. Went up and down great, left it all the way up for a couple days, what can I say had to go to work. got the battery and hooked it up, then went to lower the motor and it was stuck!!! Found the manual release and lowered it. Raised it again stuck again. Now all the sudden will not go up or down. I did loose some fluid but I didn't think much? It looks like a simple set up but I am stumped. Any ideas fellas? Maybe bled? stuck valve? am I looking at more big money?? Maybe I am missing some thing easy??? I did call the shop I bought the motor at he said to take the big flat plug out of the, looks to be the valve body down by the cyl. He said to pull it out and put some screw in to it and that should release the stuck valve. I did what he told me minus the screw thing. Nowhere to screw in to??? I know if anyone can answer this it's you fellas!! Thanks so much for any and all help!!! Brad, Trish, and kids<br /><br />
