Evinrude Trouble
- Joined
- Sep 27, 2007
- 40
I have a 1982 johnson 70hp Sea Horse Model# J70ELCNB and am having some problems with hesitation at WOT and the remote control box periodically buzzes. I have Replaced the fuel pump diaphram, replaced all the carb jets (expensive) and rebuild all three carbs, I replaced all fuel line with 3/8 gas hose with an inline filter. We did not used to have this priblem this is a recent thing the motor used to run fine without this hesitation. The boat will jump out of the hole just fine but the problem is noticed after the boat is on plane. It sounds and feels like someone is cutting back the throttle ever so slightly and thne pushing it back up to WOT and when the throttle cuts back it lasts for 2 or 3 seconds then back up to WOT then cuts back for a second kind of like a yo-yo, the motor also vibrates a little more than it used to. My second problem is that it sounds like a buzzer is going off in the control box and i have been told that this is an over temp alarm? This problem also happens intermitently and the tell tale stream is strong when it happens and it has happend when we are at WOT and when we are in neutral and have not run the motor long. Does this alarm have a thermostat that could go bad or could this be a short. I dont think the motor is over heating. I am going to replace the ignition switch because it really needs it. Another more frequently posted problem is that I dont feel like i am getting top end on the motor. I have checked the timing and it seems to be spot on for what the manual says. Have recently replaced the spark plugs. Any help with any of these problems would be greatly appreciated, thanks for reading.
