Re: Hesitation under 3/4 to full throttle
I'd suggest taking it to a shop that can hook up to your diagnostic port before you continue to throw money and parts at it. While none of the suggestions mentioned are bad, you might be able to pin point the problem with a simple diagnoses.
I had a similar problem. I cleaned everything, replaced the fuel filter, spark plugs, distributer cap, rotor, and a couple of other little things. Searched here, and got the most suggestions to look at my IAC. I did. It was a little dirty, but was not the problem.
I finally got tired of chasing my tail and took it in for a check. TPS voltage was all over the board. $38 replacement part and has ran flawlessly since I replaced it. Not a single person here posted a suggestion to check the TPS.
I'm not implying the people here gave bad advice. All of the other stuff was periodical maintenance items, but were still operating just fine.
Not saying that you need the same part. Just saying that the problem might be an easy fix. Before you start going nuts, might check into a diagnoses.
